jyrki3101
Active member
I've been doing a struggle with this tape echo project for a long time. Not an easy one for sure. Mostly everything's built from scratch 'cause I haven't found any useful information on DIY tape echoes with google .
I like the features of the Roland space echo(201) with those multi-head type echoes, and that endless feedback which you can achieve easily...But I have had this obsession to build a tube based echo unit with the same kind of features...I already have the chassis, tape transport parts and tape heads(from amp-fix,UK).Tape/DC motor speed is controlled by a PWM module which I bought from ebay. Tape transport is already working.
There are 2 channels, each using a 1/2x12ax7 for the first preamp stage.1x12ax7's in the Recording amp stage w/local NFB loop, like in a Klemt Echolette NG51. Playback amp has two 12ax7's ,with a cathode follower at the output.
I copied the tape bias oscillator circuit from an old Dynacord echocord S-62(schematicheaven.com) unit. It's using one 12au7.
I've found it very hard to find a suitable osc.transformer,The original in the dynacord echo is chassis mounted, but I would prefer a pcb mounted transformer(lack of space inside the chassis). Don't have a glue about the specs...
I have read that the F******E T*T*E Tube Tape Echo has also a 12au7 in the osc. circuit.
1. Has anyone information how it' built and what kind of osc.transformer has been used in that machine..
2.I WOULD GREATLY APPRECIATE of any kind of help, resources, links etc., anything that's related with my ambitious project( maybe TOO ambitious....
Regards, Jyrki
Regards, Jyrki
