diy-tubes.com - parts for DIY studio/guitar gear
Yes, temporary unavailable because of a fire in business center. We'll move to good datacenter soon, uptime will be better.
But all parcels are shipped! Thank you for your orders!
New arrivals: SH potentiometers from Taiwan (R24 and R16 types), including B1k, B2k, B2M, C250k,  C1M, W100k and others. 6K4P-EV tubes for tube compressor projects, amp handles, tin plated copper wire, russian VU meters, 6X4 tubes etc.
We moved to Tier3 datacenter, uptime will be better.
i tried to order that sifam style knobs, but it says they're out of stock. do you still have some?
best,
voodoo
not all colors available, but they are in stock. Please PM me color and type.
Thank you!
Mor updates: winged =C= 6P1P-EV tubes, compact DPDT footswitches,  toroidal transformers (220 primary, 2x24v secondaries) for eu 1176 cloners, micalex noval sockets, E10/E13 bulb sockets suitable for lighting your VU meter or enclosure.
Russian Germanium transistors and diodes for fuzz/GE amp makers.
transistors: GT108V, 1T308V, 1T308B, 1T321D, GT402B, GT404B, GT108A
diodes: D9J, D9B, D9E (rare version with black body and dots marking), D310
More transistors and diodes will be available soon.
More Russian mojo in stock: Russian Big Muff diodes and transistors, Russian germanium diodes (D9K, D9V), more germanium transistors: P27, P416A, MP21A, MP26B, MP42B. "Russian J201" - KP303 transistor.
Some other updates: magnoval sockets with flange, OP07, IRF840, 7815, 7915, etc.
More NOS goods available: Russian PIO, PETP, Polycarbonate Film capacitors.
BM2 PIO (paper in oil (paper in wax) hermetically sealed capacitors).
K77-1 Polycarbonate Film hermetically sealed capacitors, beloved by many audio fans.
К73-16 Polyester (PETP) sealed capacitors in aluminium housing, usual choice for guitar tone stack like other polyester capacitors.
К73-11 Metallized Polyester (PETP) Film capacitors. I've heard many kind words about this type in audio.
Also added some Tungsram ECC85 NOS tubes, more Russian Germanium transistors with high HFE - P416B, and MP15, MP20 designed for low frequency amplification.
New arrivals: 2N3055 Toshiba and ISC for Neve cloners, Russian germanium diodes D9E (glass body), toggle switched for amps (SPDT, DPDT), and some usefull stuff - if you missed in your practice: banana sockets and jacks and alligator clips. 4mm banana jacks suitable for standard multimeter sockets, so you can solder custom made probe with alligator clip or hook probe. Banana sockets are very useful in diy synth and for diy test jigs (I use them in diy power supply - banana sockets on the front panel connected with the rails). Zif (zero force) sockets available too.
For experimentators: BDY38 (2N3055 "hifi" transistor) and BCY87/BCY89 transistor pairs. Pilips NOS
In stock Russian matched transistor pairs: KR159NT1E (hFE: 160-400) in DIP-8 and 159NT1D in TO-5
New arrivals in transistors (2SK170, 2N5087, 2N5089, MPSA13, MPSA18, 2N5457, BF245C)
Tin plated copper bus wire made in Russia available too (.67mm, 1mm, 1.2mm)
Russian J201s in stock: KP303A (Rus КП303А), KP303B (Rus: КП303Б)
Niсkel housing, low noise, additional lead (housing, can be used for lowering noise, can be soldered to housing when not used). I will post real Vgs(off) measurements for these types, but many russian diyers tested them in runoffgroove circuits and other similar schematics.
FLASH SALE. Use coupon code: GET20 to get 20% discount on all products. The offer is valid until 15.07.2017
JRC4580, BS170, CD4013, CD4066, CD4047, TL062, BC108B, BC109B, knobs, dip switches, compact jack plugs and more in stock.
Cyber Monday SALE!!!
Use coupon code: CYBER15 to get 15% discount on all products!!!
Coupon code is still available. Please use it in the shopping cart:
