I think that's a different Linkwitz ( than linkwitz-riley), but may be the same Thiel (as thiel-small)sahib said:Comments from some credible personalities
I think TEF is early energy vs time test equipment...looking at signals wrt time allowed for measurements without anechoic chambers. where you can see and ignore early reflections from boundaries, or whatever.but I have not heard of TEF-20 test set
and I am not sure about measuring the harmonic distortion in cables (if there is any). But if it was published in AES then perhaps the masters can comment on this.
To measure distortion in wire, context is important. Wire begins as very low impedance so for nonlinearities in that low impedance to matter, it need to be loaded by a low impedance and working hard... This is kind of like the whole capacitor boondogle. If the cap is just loafing along, it is not likely to express many non-linearities (a gross oversimplification on my part).The test equipment used for such test has to have a THD content lower than the wire can produce. and I don't think that TEF-20 is one of them. I don't even know if such test set is available off-the-shelf.
Searching for distortion in wire seems like pretty much a fool's mission.To be able to measure that sort of phenomena in conductors requires to go down to nitrogen level temperature and even then it is still not easy to do.
And at that level you hear nothing. So why bother.
warpie said:I guess many of you have already read this but I just found it and I think it's quite interesting.
1954U1 said:But, as always, the winner IMO is an USB cable:
Cardas Clear USB is a musically neutral cable and sounds the same at any usable length, between all components.
Speedskater said:It's the same Siegfried Linkwitz, now at:
http://www.linkwitzlab.com/
The TEF-20 is an older model, Time Energy Frequency room acoustics analyzer.
The newer unit.
TEF25 USB Preamplifier
A Powerful New Tool For Acoustical Analysis
http://www.gold-line.com/tef/t-tefpre.htm
