Do you have a 3d printer?
Help Support GroupDIY:
Norfolk - UK
abbey road d enfer said:
It's the standard Autocad interface. It appeals more to people who had formal drafting tuition.
There is a possibility to work in polar; you need to check the help. Me, I don't use them. I'd rather draw a horizontal line and rotate it by a specified angle.
Either copy or offset. Copy will move according to whatever  you want, offset will copy at a specified perpendicular distance.
I guess it is all down to the user interface. I am not a trained draftsman although I took drawing classes as part of my apprenticeship back in the late 60s (before CAD was even thought of).
I use QCAD and I love its interface. You click on the line tool and a new toolbox appears with selections for vertical, horizontal, angled, parallel and other types of lines. Pick your line type, fill in the length  and/or angle and/or spacing as required and away you go. It even remembers these parameters next time you select that tool. I cannot envisage drawing a point to point line, then setting its angle and then its length as separate operations just to draw a vertical line.
abbey road d enfer
Moderator
Marcelland
It is not as convoluted as you  describe. If I want to draw a vertical or horizontal line, there is a setting that forces orthogonal moves only (F8).
Most of the times, a point-to-point line will be drawn by typing the origin and end coordinates.
I have used Qcad for some time, until it miserably crashed on me.
There are basically two families of drafting interfaces, the cartesian (Autocad) and the descriptive (Solidworks, Sketchup). The latter seem to be the most favoured by people who are not formally trained to drafting.
Some of them are unusable for me (Sketchup). Each one his own, I guess.
The interface in Design Spark Mechanical is some kind of in-between that's perfect for 3D printing and machining, but would not be accurate enough for precision work IMO.
abbey road d enfer
Moderator
Marcelland
Rochey said:
One last defence of Fusion360.
You can export DXF's wtihout issue.
You can export STL's without issue
You can export OBJ's without issue.
The biggest danger with them is losing access to the tool itself, not your content.
For most of the things we do (basic geometric shapes, extrusions and boolean math) most other tools could be picked up pretty quickly.
/R
I liked Fusion 360, and was determined to really dig in, until it suddenly became off limits.
It was not wasted time, since it allowed me to acquire some comprehension of the thought process that seems to be common to many 3D softwares..
chilidawg
Active member
ruffrecords said:
I don't have one but I have been toying with the idea for some time. Two things are putting me off:
1. Finding enough things to make with it to make it worth while.
2. Going up the learning curve of 3D CAD. I find their user interfaces horribly counter intuitive
Chweers
ian
I've been using Solidworks 3D lately to design my 3D printed enclosures (and basically any plastic parts)
Norfolk - UK
I agree it is definitely a personal thing. Like you I cannot get on with Sketchup at all. When I was still working (last millennium) I remember our mechanical designers mostly inputting at the command line despite everything else being point and click. I am sure some of them could have sat with a text editor and written the dxf file directly (which is how I used to write in assembler at the time).
Rochey
White Market Member
Dallas, TX - Formerly UK
I would be very happy to do a live zoom on basic enclosure design for groupdiy folks using fusion360. If that's of any interest. Might be a nice chance to have a beer with friends too.
Any interest?
JohnRoberts
Staff member
Moderator
Hickory, MS
Years ago I taught myself turbocad mainly because it was cheap. I used it to design my plastic injection molded tuner package. Working with an IM vendor in TX we sent my 3d cad file to China to have the tooling machined. This cost me thousands of dollars less than tooling it domestically.
I have nothing good to say about the 3d software other than it was relatively cheap and adequate for the task at hand.
I really like the precision of modern CAD, back in the day it would take multiple prototypes to get a mechanical design right. This was one and done, but I modeled up all the components to confirm they fit together in the computer.
They used to call 3d printed proof versions SLA (?) and we had a test set printed up. All good.
Rochey
White Market Member
ABBEY - THAT LOOKS AWESOME! I'm going to design some up myself this afternoon!
John - The SLA is used these days to reference 3d printed resin, where the resin is UV cured in layers. SLA/Resin printers are cheap these days, as they mainly use a LCD screen with a UV lamp, and a single stepper motor that moves a plate up from the screen. (sorry, bad description).
I mostly use my Resin printer for printing small external components, such as knobs, bezels, things that people see, as it's resolution is 10x what my FDM (extruded plastic) printer can do.
For internal components - PCB holders etc, it's hard not to beat FDM printing. Cheap, pretty quick (faster than postage!) and providing the environment isn't harsh (e.g. hot, pressure etc) it's perfectly strong enough.
dirtyhanfri
MADrid City
Any interest?
Interested, of course.
I've been using fusion 360 for mechanical design and design of multiple 3d printed parts. I'm somewhat used to It but it's always good to learn from somebody more experienced.
thecr4ne
California
3D printing really does have a place here and I wish there was some more development. Along with CNC milling it's got massive potential to revive so many impossible to find parts. That said, the real issue is the learning curve on the 3d modeling, as others have mentioned, and the lack of good 3D scanning technology. There's a whole world of folks out there creating and sharing 3D models, maybe if we find the right forum and carve out our own corner, we can interest some of those folks in building digital models of audio world parts.
As for my actual 3D printing experience, My dad has a Creality Ender 3 Pro, which worked pretty well. I had a friend help me with a simple geometric model, and after a little back and forth with the design, I managed to print myself a custom xmas tree topper that turned out better than I expected. That said, there's a lot of setup and maintenance required to print things with any repeated success, and frankly the number of parameters is overwhelming so I chose not to dedicate my brain space to it.
I really think the way to go is to find a person or group who provide a service of creating and sharing 3D models, and printing to order. They probably already exist, but I haven't done the research. Once the technology matures more, maybe it will be more accessible with less dedication required, but it's not there yet.
abbey road d enfer
Moderator
Marcelland
After a not-too-difficult learning curve, I'm pretty satisfied I can 3D-models with confidence. I'm talking about things with relatively simple geometry.
Recently I've modelled keycaps for Cherry switches. At the third try I was good.
I use Design Spark Mechanical; the online help is superb.
Thingiverse is the site for sharing designs and finding subcontractors.
The main problem is the difficulty of printing other material than PLA. PLA is not as robust as ABS, but I haven't yet managed to print the latter.
Many electronic parts are made out of glass reinforced nylon, which is extremely difficult to print with an amateur printer.
dirtyhanfri
MADrid City
I just started printing ABS a few days ago and it's working fine with 240⁰C nozzle and 90⁰ bed.
It's also needed to enclose the machine somehow, I just have it in a shelve and cover the front with cardboard.
I use hairspray in the bed to help adhesion also.
Rochey
White Market Member
Abbey, I started with ABS, and then moved to PLA. I found PLA warped WAY less and my chances of a successful print were far higher (or more likely caused by slicer settings). I've recently moved to PLA+ which I've found to be worth the extra few dollars a reel. Currently enjoying the ESUN filament of PLA+, but I do have a pack of Prusament waiting.
For anything majorly small and accurate, I've also got a resin 3d printer, which, for modelling things such as knobs is perfect.
I found for "engineering" type prints, the FDM printer with PLA is more than sufficient.
Nice examples of stuff I've done with 3d printing _inside_ the case are PCB brackets:
.R
JohnRoberts
Staff member
Moderator
Hickory, MS
My brother (older and smarter than me) just had an old crown replaced by his dentist. His dentist imaged and 3D printed his new replacement crown while during one office visit.
I suspect whatever they made the crown out of is pretty strong. :cool:
sr1200
Long Island, NY USA
Been 3d printing for probably 5 years now or so. I have a modest machine that does an 8"^3 print area and can do PLA to ABS (after I modded the hot end and a few other things). Its a top down printer so the bed only moves up/down the nozzle does the rest of the work in the other 2 planes.
Some designs you guys might be into:
Replacement clip for a Sennheiser 421: https://www.thingiverse.com/thing:2037431
Bezel for LA2A: SIFAM AL39 LA2A Meter Bezel by sr1200
Mic Flange Mount: Flange Mount by sr1200
3/8 to 1/4" reducer for "Fairchild" knobs: 3/8" to 1/4" Reducer by sr1200
abbey road d enfer
Moderator
Marcelland
Rochey, I've been giving it a thought, but I'm concerned with fumes, smell and cleaning.
What's your experience on this?
