tardishead
I am building a 670 clone at the moment and I had a nightmare with some distortion in limiting.
After literally months of troubleshooting I identified the problem.
The main time constant cap was very leaky and was letting the program material bleed through into the control voltage. This was particularly bad from bass up to 2khz.
I replaced it and bingo distortion went away
I was literally going to scrap the project after spending so much time and money.
The cap in question was a 1uf MKT 250v yellow poly film.
I never considered a brand new cap was faulty and looked at everything else first.
Big mistake I will never assume this again.
And then I looked at an old federal clone I had built that never worked out. I thought I had a oscillation/motorboating problem with it.
And it also had one of these mkt caps.
I replaced it and couldn't believe how good the unit was when I checked it out.
Wow what a royal p.i.t.a
So can someone explain what exactly this problem is
Also I tried to look for info on what type of caps to use in timing constant circuits. What are the best?
And is there any meter out there that will diagnose leaky capacitors preferably in circuit.
