CCorcoran
Member
I hope someone can clear up a few problems I'm having repairing a Drawmer 1960.
In Bypass seems to work (using Aux input) CH2 meter ok, CH1 doesn't move, it is getting signal to the meter
Valve heater cct (7812 - gets hot and noticeable heat damage around the 56ohm resistor / Diodes and 2200microF Capacitator (But giving 11.3V)
when in Normal CH2 Attenuates considerably, you have to turn the gain (pot next to VU meters) upto to maximum, and then only get half the output of channel1 with no gain
1) is channel one behaving as it should, ie in Normal mode should the amplitude going through be the same as the bypass (Not well skilled in using these)
2) if so, any ideas what to look for. This is a later 1960 than the VCA potted variety. and the schematics I can download from here don't seem to match
3) Do the meters fail -
