Dual rail PSU
beatnik
Italy
I am making a linear power supply with two outputs, see attached schematic
top part is 32V for audio circuit
bottom part 12V for relays and LEDs
I am trying to make this from a single 12V AC transformer
I have noticed that when the 12V section is connected there is an increase in hum on the audio circuitry powered by the 32V rail
If I remove R7 the noise drops considerably.
Do you have any suggestions ? Perhaps the rectification of the 12V section needs changing ?
    19.8 KB
My guess is IC1 doesn't have enough dropout when the 12V rail is sourcing current (dragging down the 12VAC slightly).
What is the voltage at the top of C9, and V2+, both with and without R7 populated?
The margin is tight but I don't think this is the cause of the problem
There is 35.4V at the input and 32.2V at the output of the regulator
It makes no difference whether R7 is in or out of the circuit, however the noise further increases when the load is connected to the 12V rail
To give you an idea, the noise level without R7 is -74dBu, with R7 in circuit but no load it's -66dBu, with load -56dB
Throughout these variations the input to IC1 remains constant at 35.5V and the output at 32.2V
I have also tried the 12V rail without LM317 section and leaving it unregulated but the same problem occurs
Could the problem be caused by an interaction between the rectification of the 12V rail and the voltage tripler for the 32V rail ?
It's drawn strangely to me, now that I look closer.
For example: you've declared AC2 as the common line for both supplies, so I don't see how it's possible for D9 to ever turn on, once C10 charges.
A common problem in power supply design is dealing with reference ground integrity. PCB traces have finite resistance so current flowing in those traces will cause voltage drops that can corrupt clean references.
It helps to visualize PCB traces as resistors so the voltage drops are easier to conceptualize.
A common area of problems is around reservoir capacitor grounds.
It's typical to see a bridge rectifier for the 'bottom' supply: see this (which is a doubler version, so would need a third stage added for a tripler):
dualsupp2-png.769042
