Dynacord Gigant
ABsoundrecordings
New member
Does anyone here have a Service Manual / owners manual for a Dynacord Gigant?  I have just rebuilt the entire pre-amp section, replaced all resistors in  power and pre-amp section, re-tubed, and re-capped the output and filter capacitors.  1 week of work and it sounds great.  However, I don't want to kill it.  It was originally intended to be a PA amp and I am using it as a bass amplifier.
It has a two 4 ohm, two 8 ohm, and two 16 ohm speaker outputs.  I need the manual to see if I can get away with using one of the two speaker outputs, or if there must be 2 of each speakers used to provide the proper impedance for the amp.
Maybe this can be seen from the schematic?
  • Gigant (unknown revision)(1).pdf
    137 KB
