You don't need to connect it "backwards". The 1:10 ratio will bring the level up by 20dB, which will make it close enough to the level a typical pedal expects, and the impedance will be converted from 150/200 to 15/20k, which is also close enough to the typical source impedance of an electric gtr/bass.Hi, i would like to use dynamic mics(no phantom power) with guitar pedal and i have some shure 1:10 mic input transformers from a Shure m67 mixer.
Is it enough for gain and impedance match if i conect "backwards"?
Use a Normally-open switch (NO) across the mic. When teh contact closes, it mute the mic and does not enter the circuit in high-impedance state, which is bad for noise performance.Is it simple to have a switch to mute the mic signal?
