eagle consistent schematic/board...
3nity
MTL, CANADA
i don't understand is there any function than enabled this......
normally is impossible to erase a component in the layout window but this happens some times....any one?
I just renamed a resistor and when i open the layout it seems that he don't recognize it ....it says that the old name resistor is missing.
thank you for your help...
You may never change anything in the schematic if the board window is not open (or vice versa) in Eagle. Just rename the resistor to match its name in the other window and run the ERC, afterwards things should work.
If both windows are open, you can erase a component in the board window if it has no net (= green line in schematic editor) attached.
HTH
;Matthias
