EDAC 90 Pin PCB mount
pucho812
third stone from the sun
Does anyone know if the EDAC 90 connectors have a PCB mounting version.
I have an Idea where I would like to convert some EDAC 90's to RJ45 and I figure that can have an edac 90 on one side of the PCB and rj45 connections on the other. It may not even be worth the hassle, but thinking about it.
I could have sworn I have seen an EDAC90 that solders directly into a PCB but I could be wrong.
Like this one Digikey Link, I have been thinking about the same thing recently.
yes except that one is a 38 pin and not a 90 pin. But I can do searching from there. thanks.
further update, I can use my previously owned edac 90 blocks just need different mating pins.
Ordering Code Notes for the various mating pins
516-290-500 Wire Hole
516-290-501 Taper Tail
516-290-520 P.C. Tail
516-290-540 Wire Wrap
516-290-541 Wire Wrap
516-290-542 Wire Wrap
516-290-590 Crimp (Loose)
so just need a PC tail...
