Edcor Replacement Transformer for PM1000 Tamura GA80080
abeLovesDIY
Active member
Hello,
I know the Tamura is a 600:600, but would like to know which Edcore would be the right replacement for some PM 1000 direct out channels. The PC Series, TPC, Series, or MXL Series should work, but I don't want one that needs a PCB and so was looking at the WSM. Is there a consensus as to which is good enough but not overkill for a simple 1:1 600:600 transformer?
WSM 600:600 , it will work fine for general use the price is about as good as it gets. Only difference is the original has shielded can for lower noise.
