ben9000
New member
Hi all, Ben from Australia here, this is my first post here. Please excuse the length of it but I feel like writing about this conundrum might help me as well as you guys understand what's going on. Okay - I've got an Edirol UA-5 dual pre/audio interface which I use in stand-alone mode for field recording. It's main shortcomings are the quality of the pre's (not enough gain, last 25dB of gain bunched up between 4-5 o'clock on the pots, not 'robust' sounding). So among other more minor tweaks, I've made up on perfboard some INA163-based pre's. I followed the datasheet example schematic and they function fine as individual modules, with lots of gain, very low noise, and a nice transparent sound. I've made up a 12-position switched gain control which is lovely and even and lets me match the channels perfectly. So that's all good. The problem arises integrating this double-pre board into the UA-5. I've mounted the board inside the case and powered it etc. I can inject the output of the new pre via a 47uf electro cap into the AD chip (ak4524) with no problems. Clean as a whistle. I've removed the original surface mount blocking caps (their printed labels read line by line "1","50S" and "3KN" - can anyone shed light on this?) thus disconecting the stock input circuits from the XLR's. I've taken the p48 source (after the stock 6.8k resistors) and sent that up the XLR's on pins 2+3. This is blocked by 2 22uf 63v electro's (I have also used 47uf 50v non polar electros). All this is fine - it basically works perfectly with self-powerd and dynamic mics. But as soon as phantom power is engaged all sorts of strange phenomena begin. It acts as an AM radio reciever. It acts as a theremin, with several nasty cross-modulating tones rising/falling depending on the proximity of my hand. It will magically stop (or reduce, depending on it's mood) these symptoms if I touch the case of the two 9V batteries that power the pre's. They also disappear if I place a wire link between the metal outside shell of the microphone end of the XLR cables. On the other hand, sometimes this will have no effect at all, or the opposite will be true. Meanwhile, the pre's are still basically functioning, but will cut out when gain is bumped up to about 15dB away from max. When the gain is backed off, they will come to life again. When phantom is turned off and settles down (takes 30 seconds - rather long?) it all returns to normal. I have given up exploring all of the permutations of this behaviour and am now just trying to figure out why p48 has this effect. Do any of these things sound like they have an immediately apparent cause? I don't know where to start to resolve this problem. I will continue to check that phantom is being blocked from the pre inputs properly, but if any of you could shed some light on this problem it would be greatly appreciated. I'd be happy to provide you with as much info about the UA-5 as I can to help the sleuthing.
Cheers, Ben
Cheers, Ben
