Egnater Rebel 20 Guitar Amp
CJ
GDIY Supporter
California
just a blown B+ fuse, those small sized fuses do not seem to stand up as well as the AG3,
bumped it from 500 ma to 1 A,  as full blast current was up there,
Quad of power tubes, 2 ea 6V6GT and 2 ea EL84 with a blend knob to use either or which is a novel feature,
but we get to have a lookise inside !
had to fill in ref designators only to find out later that there is another , schematic with the values but no big,
preamp with blue = dc red = ac
marshall follower drives stack,
dual gain pot on preamp,
PI and mix circuit
i heard no big diff between EL84 vs 6V6, maybe some Amperex 6BQ5's would add a difference,
amp gets slightly louder with the mix knob set for both tubes,
this amp also has a wattage adj knob which  starves the PI via cathode,
and the power amp with OPT info,  about 9K P-P into voice coil,
might be a bit high for both tubes on parallel,
nice sounding amp!  could be simplified as a project by leaving off the mix circuit,
