Working on a repair for a friend. Basically from what I can tell the issue is that the unit is not getting powered. I seems pretty simple but I'm baffled. Schematic is attached. It goes- 24v input -> 150 1W resistor -> reversed 1N4003 -> LM7915 input. There is also a filter cap from the 1N4003 out to ground. Current stops at the diode. I don't really understand having the diode and filter cap reversed like this. I tried to mock up an exact power supply section completely separate from the pedal and I get the same result, nothing after the diode. What am I missing here?
