hello all
I bought an electroluminence panel at www.elfa.se/en/ (partnumber 75-561-29 ) just to play around with..but the frequency response is just 100-3000Hz..is that what they usually are or is this poor?
the idea I have is to drive it with a small 220/12 volt transformer ( feeding the 12v with a small amp such as LM386 and using the 220v primary to drive the el-lum )
I guess its fairly obvious I'm building a low voltage optical limiter :grin: I've been using LEDs before, but the on/off caracteristics sometimes introduce distortion at lower frequencys and when I tried small lightbulbs (2,4V/0,16W) they are too slow...
..so back to the question..is this frequencyresponce what I should expect from electroluminence panels or are there others out there that are much better
any thoughts/answers are much appreciated..
johan
..and yeah,..lowvoltage as in batterypowered, easy to carry, stompboxe-size..
johan
