Clbraddock
This is just something I've wondered for awhile and been unable to ever find an answer googling.
It seems that radial electrolytic capacitors are often mounted a little bit above the board/pcb supported by their leads and sometimes some glue. Why are they mounted this way instead of flush with the bottom of the capacitor touching the pcb. I believe the glue is to prevent mechanical/vibration damage, but why have the leads sticking out to raise the caps higher? I assume there is a reason, but I haven't been able to figure it out.
