Hello all,
I am not sure whether this should be in this thread of the Truth Table section but will post here, please move it if you need to.
I wanted to share something I am working on at the moment. I have built a single channel vari-mu compressor which will be largely controlled by the embedded device BeagbleBone Black, I am also using the mBed for some further app control developments.
The compressor has motorised pots which can be read by analogue input pins, and controlled via the digital output pins via a Half H driver.
I have written a biquad filter class that is being used for the sidechain EQ. I am currently working on taking the sidechain signal a little further to manage the attack and release duties but I have not got there yet - this is mainly due to me needing to build a negative voltage follower to drive the input grids.. The analogue inputs on the BeagleBone Audio cape are being used, the cape also has some speaker output terminals which I will be playing around with to drive the side chain.
Attached is a pretty rough schematic of the project so far. Some values are not accurate and I have left a few smaller details out until I have a finalised design, but hopefully this gives a clear idea of the goals so far. I can upload the code as well if anyone is interested.
I am interested if anyone has done a similar project and can offer any further suggestions for where this might end up.
There are a few really interesting concepts possible with this, it will be great to get some collective ideas to push it further!
All the best
Habibi
All the best
Habibi
