Axel.Thoma
New member
- Joined
- Nov 14, 2011
- Messages
- 4
Hi Folks,
I have a problem with a EQ1A. Actually I bought two used devices and had to change the tubes because some of them didnt survive the transit. Because of this I dont know exactly how the sounded before the new tubes.
The problem is that both of them generate noise with a fundamental at 50 Hz (net frequ.) plus harmonics with a amplitude of about -60 dbfs which is too much for the purpose I bought them. I attach a picture of the frequency content of the output signal to this post please keep in mind that ist somehow weighted (the ampltitude axis isnt linear in the picture!). I have got some questions now and maybe someone has a clue.
First of all is there anyone who has a schematic?
Can it be that it is not the PSU? - I adjusted all parameters on the amp + psu board, DC voltage and the Offset + basic Gain.
If you think the problem comes from the PSU what can I do to fix it. I thought about changing the Caps in the next step since they seem to be old and not of good quality.
Waht do you think? Thanks a lot and regards,
Axel
Axel
