soapfoot
Hello!
Just finished up an EQP-1A. It came out nicely! Decided to run some sweeps today and noticed an anomalous behavior.
Circuit is identical to schematic. Triad HS-66 input, Cinemag CM-HS29 interstage, Cinemag CM-S217D output.
All performs well except there's a curious rising frequency response peaking at about 18.2kHz before rapidly falling off.
It seems as though perhaps one of the Zobel networks needs to be tweaked (to compensate for slightly different interstage and/or output transformers?)
All values are currently as per stock schematic (270pF and 43k on interstage secondary; 620R and 3000pF on output secondary).
I'm more of a recipe-follower than a design engineer, so I'm not sure which of these networks I should begin experimenting with, nor which direction my experimentation should take (increase/decrease cap? increase/decrease resistor?), or even whether I'm on the right track entirely.
The behavior is present whether the EQ is engaged or bypassed (below sweep was taken with the unit in bypass).
Appreciate any insight/hunches/methodologies!
