well, that lawrence guy was a good engineer.
he choose a part that was very common.
the sensor in the common household motion detector.
so they should be around in some form for quite some time.
we might have to resort to creeping around the neighborhood until a lamp goes off.
then the next step would be to map the entire neighborhood, prefreablly, in some other neighborhood, with green dots on a AAA map.
then, under a bright sunlit sky, the purp creeps out again with a trick or treat costume and brown Whole Foods shopping bag, doubled up with handles.
when the cops ask you why you are out trick or treating in the middle of the afternoon with a propane soldering iron, tell them you are blind.
then tell them the truth, that you are really looking for vactrols.
that will scare them so bad that they will set you free quicker than hudie ledbetter.
one good thing about old stock, kubi ordered up a set of mastering T4's, each unit has to track exactly the same for accurate stereo reproduction, minimal cross phase distortion, and ample simblance of symbols.
therefore, i have been aging these precisely matched cells for two years in an effort to make these units provide a lifetime of accurate mastering.
