Greetings, I’m going crazy with a friend’s Eventide H3000SE. Fixed the usual short circuit on the +/-15Volts power supply lines (due to two tantalum capacitors), now it would seem to work properly, but actually when you try to load the parameters of the standard effects, the display after an attempt to load, shows "algorithm missing", I downloaded the file . bin of the diagnosis program and I stored it in an eeprom, run one by one all tests, the only ones showing errors are the one numbered from #39 to #48. Can anyone suggest me where to look ?
Thank you in advance.
-Roberto-
-Roberto-
