thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
A project I have (runs in Class A, so no dynamic loading) drains 1.35A @ 18VDC per +/- rail. I used a toroidal with a 2.2A secondary rating. After around 100 hrs use one of the secondaries has gone open circuit.
Description: each secondary (2 x 18 VAC) feeds its own bridge rectifier, which feeds LM338K Vreg (creating 2 isolated supplies). These in turn feed sub-PSUs. The total reservoir capacitance for the LM338K circuit is only about 4,700uF - but the following sub-PSUs in total have around 60,000uF of reservoir capacitance prior to their 317 / 337 Vregs.
What would cause a secondary to fail open circuit? Usually an overloaded or overheated toroidal will go open circuit on the primary, right?
Could the substantial amount of capacitance coming after the LM338K pre-regulated circuit create such an inrush current spike as to damage the secondary? The secondary failed after being switched on for 4 hours...but the venue is renowned for voltage spikes...
Toroidal - 18VAC secondary - Pre-reg LM338K supply @ 21.5v - several sub-PSUs (each with substantial reservoir caps prior to Vreg) all feeding 18v out.
Thanks in advance.
Thanks in advance.
