Hi everyone,
First and Foremost, I'll admit I know next to nothing about electronics, and this is a new venture for me.
I've done some looking through old topics, and read up a bunch on parametric EQ's- specifically through a bunch of the Meta threads, but have yet to find exactly my answer.
I'm wanting to build an onboard single band PASSIVE parametric EQ section for a guitar, and I think I have most of what I want narrowed down, but I'm a bit confused about how to wire up my Bandwidth (Q) potentiometer.
There Two pictures are essentially my Circuit- I'll have a series/parallel switch to go between the two diagrams: cut and boost for my Potentiometer, so I can select whether I'll be cutting or 'boosting'
What I'm unsure of is how to wire a bandwidth pot. From what I read, All I need to do is wire a pot in series with the Inductor to add/remove resistance and create more of less of a cut/boost... but I already have a pot controlling the circuit above. All I really want to do is reshape the curve from more narrow to more broad, so that I can leave the pot controlling the whole circuit for adjusting how much of a cut/boost.
Does any of this make sense? It seems like just adding a pot to the LC circuit will do the exact same thing as the pot I have controlling how much cut/boost.
Keep in mind I really want to do this all passive.
