So this has been quite the journey. I have to admit I sort of lost interest at a few points along the way but I finally made it through to the end and it was well worth it. I would like to say right away that the EZ1290 boards worked perfectly right from the start. Same with the parts kit form ALM. Even when I tested them with the oscilloscope, both preamps tested perfect with no adjustment necessary. Besides the complexity of trying to figure out how to fit two EZ1290’s with their transformers and a power supply all into a 1U rack unit, the biggest problem I had with this project was with my choice of power supply. Instead of using the JLM PSU as suggested in the instructions, I chose to go with another PSU. The MNATS Variable +48V sold by Hairball. At this point I would like to state that the difficulty I experienced was no ones faults but my own and not the designer of the EZ1290, Madriaanse. I wanted to house the PSU inside the same 1U case that the preamps would be housed in so that there will be only a power cable out the back. No wall wart or separate PSU box. Anyhow, I chose to go with the MNATS Variable +48 since it fit the bill and was cheap. BAD IDEA! This PSU is not bad design wise but the actual PCB is crap. The circuit traces and solder pads are so small, it's next to impossible to even solder the components on. This was such a problem that some of the traces on the PCB broke. To remedy this, I had to scrape quite a bit of solder mask off and solder bridges to reconnect parts to the traces. My PCB required six fixes. I don't mean to be overly critical of the MNATS PSU but I have done a bunch of research on PSU design and even designed one for an 8 channel API 312 I built myself. This one is just plain bad. Regardless, I was able to fix the problems I had with the PSU and once remedied, the preamp worked excellently and tested perfect right from the start. I would like to thank Madriaanse and ALM for making it possible to build a two channel 1290 for less than $500. Way to go.
