Isn't it normal practice to do this when making TRS to TS cables? Is it because of potential long length of the cable?Good question. I am not sure why anyone is recommending connecting the spare conductor to the screen and connecting it at one end only. If the length of the cable is less than one metre then core to screen capacitance is not an issue so you might as well just connect the two cores together at each end and treat it as single core cable.
All fader wiring in my mixer is shorter than 30cm and wired according to this picture:
The specs of the Mogami 2944 in regards to capacitance:
Not sure what the different K's mean and which one it is. I'm using 1k faders.Capacitance at 1kHz, 20°C
(Partial C. Value)
K0: 40 pF/ft (130 pF/m)
K1: 3.7 pF/ft (12 pF/m)
