Federal AM-864
Help Support GroupDIY:
skal1
Birmingham,uk
drpat
i have already check R1 measures 2.25 Meg
as a side note i did find that if i removed R1 the oscillation stopped. if the c1 was bad would you see the effect in att mode, when in att mode their was know release is this due to r1 not being in Parallel with C1.
I will recheck with R5 full clockwise , and take reading ref to ground ..
Should the federal be on while taken the resistive readings.
I will post 2morrow
thanks again drpat
skal1
skal1
Birmingham,uk
Hey me again here are the new values follow your set up  method.
V4
pin 1:0 ohms
pin 2: 300k
pin 3 : 1.5 ohms
pin 4+5 : 2.37meg
pin 6: 45k
V1
pin 1to5: 0 ohms
pin 4 :2.30meg
pin 6: 1.032
pin 8:27.6k
V2
pin 1to5: 0 ohms
pin 4 :2.30meg
pin 6: 1.032
pin 8:27.6k
I also replaced c1 , it had no effect on the oscillation with threshold and current at max. so what i did next was to parallel the two 1uf capacitors  to make 2uf and the oscillation  was gone  ???.
does this rule out the c1 as the suspect component i think so what , do you think?
skla1
skal1
Birmingham,uk
drpat said:
These are the readings that are off:
V4 pin3: your current control is probably mis-set. Re-align your current control and lock it down for now.
manual says set to 2.5 vdc correct?
drpat said:
V4 pin4&5: This reading points to R11 being high... my guess is that it reads in the neighborhood of about 120K, which would be waaaaaay out of spec. Can you verify that R11 is within tolerence? If it really is out that far... replace it.
Will check and replace 2morrow
drpat said:
V1&2 pin4: a tad high. replace R1 with something that's in tolerance to bring this within specs.
drpat said:
V1&2 pin8: Did you change your plate resistors BACK to 12K?
I did replace plate resistors back too 12K , so that  is ok.
drpat said:
Another thing that you can try is croc-ing another 22µF cap in parallel with the single 22µF cap AFTER L1 to give you 44µF total. Or just put one in permanently and leave it there.
Will try that 2morrow
and thanks again, i think where really close to finding the problem
skal1
skal1
Birmingham,uk
OK did those exchanges
R11{46.7k
R1  {2.08 meg
V4 pin 4+5 : 2.07meg
    pin 3 : 167 ohms
V1 pin 4 :reads 2.01meg
V2 pin 4 :reads 2.01meg
still oscillates though. ???
skal1
skal1
Birmingham,uk
drpat said:
What resistance readings are you getting from V3 pin1 to ground, and V3 pin4 to ground?
V3 pin1 to ground, 470 ohms
V3 pin4 to ground ,471 ohms
drpat said:
Did you add the extra capacitance after L1? You could just use a single 47µF cap to replace both of the 12µF caps like I did.
yes ,just put a 25uf across the one that was their.
drpat said:
You might need to match V1 & V2 better. You tested all of your tubes, right?
i have no tube tester.how can you match the tubes , can they be matched in circuit ? what should i be looking for in a good match... current /voltage...
skal1
emrr
NC, USA
The addition of a balancing circuit on the plate side would be simple and useful.  I believe several people have presented one here before.  Won't solve a drastic mismatch, but lets you fine tune one that's already reasonably close.  Some limiters come with this already (BA-6A), Gates used shorting jacks in the path to insert current meters for in circuit measurements.
skal1
Birmingham,uk
rafafredd said:
here´s a plan... don´t mess with the cathode:
sorry for the mess, but it should be readable.
so something like this should work..
skal1
