Deepdark
Hi guys
Just finished my Fed and it sound really good, exept for the motorboating sound. So far, it has been located in the sidechain circuit (pulling out 6sq5 cancel motorboating). All voltages are good, pots are working. So, my thought is that trouble must be around C5/6, R6/7/8/10/11. For now, I tried moving some wires, moving B+ farther, playing with different setting, but it's still there. Once the unit start to compress, motorboating appear. With threshold off, curent ctrl off, there is a little motorboat, but once I turn it a little it dissapear and there is certain spot were it appear again. Threshold pot at around 12-1 o'clock motorboat appear.
Motorboating being a 5-10hz oscillation, what in that particular unit (or vari mu compressor) can cause motorboating? Is a certain ground scheme can be the culprit? I linked my schematic .
So far, I think about some things that could possibly be the cause. Maybe layout related.
1. I installed R6 on the same board as my psu, at the other extremity of the case. The run to connect screen grid of 6sk7 is pretty long. Could be acting as an antenna?? So moving it on the main board could possibly help, at least reducing the run.
2. Installing C6 straight at the tube socket, instead of runing wires from the tube socket to it and get back.
3. 6SQ5 cathode goes to R8 wiper and then I connect the wiper to R10 pin 1. Maybe I should wire pin 3 to both, so I would have 2 wires comming from pin 3 instead of 1 and having him split at the pot.
4. Connecting R8 ground to the psu ground, instead of the signal ground point.
5. Adding another filter cap at the psu
Other than that, what should I check? Thanks for the helps. Much appreciated.
