bxt403
I was wondering if anyone knows if an LED exists that can replace the stock pilot light bulb in Fender amps. In my case- I need one for the '63 Reverb Re-issue. I know that (apparently) the Champ 600 uses an LED so I wonder if there's a drop-in replacement for the 6.3 Volt AC bulb that's used in Fender amps.
According to the schematic- the lamp's connected directly to the PT's 6.3VAC winding but there are 2 x 100 Ohm series resistors and then the other supply voltages to the tube filaments.
I'm hoping there's a parts supplier or manufacturer who have a "drop-in" replacement (in that I don't need to add any diodes or resistors in series with it) for the bulbs found in Fender amps (albeit the bulb in my reverb tank is soldered). Hopefully- through Mouser or Digikey.
I found a link in a forum post on another website to some on eBay but they appear to be rated for 6.3V DC.
Any help is appreciated (especially if some one has successfully replaced theirs with an LED). My concern is the excess power that's wasted from a simple light bulb indicator. As is- my unit consumes around 20 Watts so I'm certain I can drop at least 1 Watt (which is A LOT: all 9 pedals on my pedaboard consume ~1 Watt).
