fet boy
usekgb
Salt Lake City, UT USA
I would like to add an impedance balanced output to this pre as referenced here:
http://www.jensen-transformers.com/an/an003.pdf
Can I simply wire another 10uF cap from pin 3 to ground, or would I need to add another resistor as well.  I am unsure of the existing output impedance of the circuit, and what value, if any, resistor to add.  This is for a very compact portable build, and I just don't have room for an output transformer.  Thanks for the help!
3nity
MTL, CANADA
Actually the fet boy its impedance balanced.
the hamptone needs an op transformer.
Do you have a look at fet boy schem?
Hamstertronix
New member
Hey there, I built 4 fet boys a few years ago, and now 1 channel is intermittent.  Does anyone have a working link to the schematic and layout diagrams?
I love these pres. Been otherwise my workhorse go to pre's.
PeteC
resurrecting this......
now that my 2 Calrec EQs are well under way I am interested in doing a couple of FETboys - but the project links are no longer operating on this thread.  I've googled a lot too.
anyone have the info for me to build using self etch pcbs ?
Pete
rock soderstrom
Tour de France
Berlin
Hi Pete,
here is a lot of information.
https://web.archive.org/web/20110501011353/http://www.diyfactory.com:80/projects/fetboy/fetboy.htm
https://web.archive.org/web/20060819043420/http://www.diyfactory.com/projects/fetboy/hamptone_fet_scan.jpg
8)
pstcho
Greece
Hello guys, i finally build this preamp but i see the transistors are getting super hot
Heating could be solution or i made a mistake somewhere
I found several forums talking about it but no real explanation
3nity
MTL, CANADA
Transistors on mine were really hot as well. If I remember correctly calibration should limit the heat.
pstcho
Greece
I calibrated as described and indeed it works fine, just scared they won't last much maybe nowadays we can find other transistors holding better this curent ?
The ztx and 2n5457 are running very hot
pstcho
Greece
Lots of gain in this preamp, it's crazy
Also it feels like it sounds brighter than all the other preamps i own, anybody else noticed that ?
