Filament coil without c.t.
Deepdark
Quebec, Canada
When We have a filament coil which doesn't have a c.t., it means the coil is 6,3v-0v, isn't it? By creating an artificial one with a pair of 100r to ground, does it force the coil to be 3,15v-3,15v? So We strap tubes like 12ax7 the common manner, pin 4-5 and 9, is that it?
yes, strap 4-5, connect to one green wire,  connect 9 to the other,
100 ohm virtual CT is very common,
more circuits here>
http://groupdiy.com/index.php?topic=57166.msg728663#msg728663
There's no "zero" on a winding.
When you test it on a bench, you pick one lead, *call* it "zero", and measure the other lead(s) *relative* to that. 0-6V.
Yes, when you connect a symmetrical network *across* the winding, and call that mid-point "zero", now you will find half-voltage on either side. 3-0-3V.
The tube does not have an internal "zero" either. As long as one leg is 6V apart form the other leg, it heats.
Thanks guys. I've read some data sheet from edcor recalling one lead 0v or common, while no c.t. Which gave, ie, 5v-0v or 5v-common. Common should be a better way for naming it i guess
