I need to add some 0.1uF caps on the PSU rails (+/-) to earth, of some opamps, some already have them (ceramic) and want to understand the methods people use to find earth rails in an audio circuit, I do have a schematic but am not super duper with them yet.If I went it alone I would have to painstakingly follow traces to a known earth point on chassis / balanced I/O and this might be fraught with encountering components which mean if it's too distant from the opamp I might not have enough lead length on the earth side or it is not longer a reliable earth due to components in the circuit (I have have some polpropolene 0.1uF axial capacitors with 30mm leads each side) Any advice would be great, the unit will be in bits and not possible to connect to power, I do have a multimeter. thanks
