synthi
Hi people,
I`m finishing my dual Pultec eq, first, here are some photos:
The channel 1 is working without problems, but the channel 2 is having an strange (for me) problem:
-first the signal is way louder than channel 1 and noise is about -65dB rms(-110rms for channel 1)
I swapped the tubes between the channels and still the same, so the tube is not the problem
-Also channel 2 hi boost and bandwith don`t work, attenuation does work and lo boost just a kind of (about the half gain as channel 1)
Then I swapped the front PCB for channels 1&2 and still the same problem, channel 1 is working and channel 2 exhibit the same problems with channel 1 front attached, so the problem must be with the main pcb. I checked the components and all sems to be ok, not bad solders, not broken pcb lines, and voltages are the same for the 2 eqs. the only I can`t test is capacitance for the condensators...
I`m using 3 transformers: a large toraid with two 12v secs each one feeding an eq, then 2 small trafos for 12:220, one for each eq. all voltages are ok. I measured voltages at several points from both channels and both shows the same voltages...
ITOH, both channels have 6V at tube heater, is this ok?
Hmm, I`m not very experienced and I`m really missing here.....
Any help is really apreciated.
Synthi.
Synthi.
