Id been on the look out for a Firewire audio interface for a good while , some are still holding their value remarkably well despite compatibility issues with modern hardware ,
I happened upon a TC electronic Konnekt24d , looked like an interesting box , all the standard stuff 'you want from a computer sound interface like 2 mic pres, four line inputs ,four line outs all balanced ,spdif/optical/adat /midi.
What this unit and other units in the TC Konnekt range have is a built in DSP which can be preset to work without a computer attached , the exact processing depends on model , in the case of the 24D you get an instance of the TC Fabric R and Fabric C , which are reverb and eq/three band compression plugins , these are usable in realtime ,or very close to real time , good enough for live performance , the set up menu and presets are accesed via a pc or mac based TC NEAR control panel software , and you can save the units routing and soft controls to one of three memory presets for stand alone opperation .
Other units in the Konnekt range can also co exist on the same firewire network ,effectively operating in parallel in terms of processing power, either within a daw or standalone . When used with MAC the native fireware port makes life easy , its a bit more work to get it going via Windows , and there was some weeping ,cussin' ,knashing of teeth and pulling hair to get my 24D to talk to the legacy pc and OS ,but the blue Firewire led is solid now everything seems to be working very well . Drivers and software for the Konnekt range were maintained up until a few years ago so you can expect compatibility with modern windows , I found for windows Xp ,version 2.5 of the TCNEAR program was as high as I could go or Fabric C/R functionality was lost . Theres a few different flavours based on the same basic box from TC including Konnekt 24d, Konnect Live, and impact twin, all dedicated to live performance usage .
Something like the Konnekt 6 desktop could be a really smart way of integrating standalone eq/effects and recording/vst capabillity into a Tube mixer project ,
Below you see the Fabric R reverb, looks like it was intended for touch screen operation ,
