Focusrite ISA 110 HPF / LPF Distortion
outoftune
canada
hi, a client has brought me a Focusrite ISA 110 rackmount ( http://www.soundonsound.com/sos/jun00/articles/focusrite.htm )
The preamp functions properly, but as soon as I engage the HPF or LPF I'm getting a drop in level and a lot of distortion.
I have the schematics and I'm guessing it's one of the 5534 opamps, just wondering if anyone else has experienced this issue before?
My first guess would be a dried out electrolytic - or a 5534 like you mention.
Make sure to put in a IC socket when replacing opamp - the pcb doesn't like multiple soldering cycles.
Jakob E.
yes a dried out electrolytic was one of my other suspicions. thank you for the suggestion jakob, much appreciated!!
Wow..when caps from what you consider being yesterday dry out (2000), you know you are getting old. Or focusrite put some low quality caps in that 3000£ strip.
I don't think it's about low quality parts, but about the rather high temperature inside those units.
You can easily run audio much cooler, but it won't sound as good...
Jakob E.
Oh... If i understand you correctly:
Running Transistors/ICs responsible for the amplification at the maximum to get maximal headroom will run the circuit hotter, This will heat the CAPs and dry them faster?
I have a couple of active faders from East Germany that have caps with burn marks from the transistors they decouple. I guess you can't put the caps to far away because that would introduce noise, and they need to be big enough to let the low end through. I might have it all wrong though?
Sebastian
