Thanks for your reply !
I did some research last night and here's what I found out :
ELMA switches are still made (I though they were discontinued by the manufacturer) but they are very expensive and if they happen to fail again after some time they might not be the best investment... However, I looked in their datasheet and I guessed wich references are mounted I my 215 :
HPF : 4 poles / 6 positions 30° ELMA 01-2263
LPF : 4 poles / 6 positions 30° ELMA 01-2263
LF : 2 poles / 6 positions 30° ELMA 01-1263
HF : 2 poles / 6 positions 30° ELMA 01-1263
Line : 1 pole / 12 positions 30° (7 are used) ELMA 01-1123 or ELMA 01-1183
Mic : 2 poles / 12 positions 30° (11 are used) ELMA 01-2123 or ELMA 01-2183
http://www.elma.com/en/products/rotary-switches/rotary-switching-products/product-pages/type-01-detail/
I now have to figure out wich Grayhill switches match these !
After some research it seems like the 71 series (red and gray body) is a match, but I could use some confirmation
The fun begins when you have to sort out wich Grayhill reference to use... This doc helps : http://www.grayhill.com/assets/1/7/Rotary_71.pdf
The diameter should be "A", angle "30", number of decks "01" or "02" depending on the purpose, pole per deck "1" or "2".
But I can't tell if I need a precise number of position or adjustable stops.
Anyway, here's where I am, if you find your notes it'll be great help, thanks
Best regards.
PS : if a moderator thinks I should open a new thread about this (ie "Focusrite ISA 215 Rotary switches replacement"), please let me know and I'm sorry I haven't.
PS 2 : sorry for my sometimes poor English, it's not my main languange... I hope I'm not too hard to read
