found simple software for stripboard/veroboard and perfboard layout creation
1954U1
Italy
I've found "DIY layout creator", a very useful and simple freeware software
[there is a CVS java based open source linux version too].
I've tried it, its really great IMHO, because its ingeniously focused on stripboard/veroboard and perfboard layout projects too,
unlike other bigger softwares.
a quick google search and you will have more links than you can shake a stick at...pretty good program, I used it before i went eagle and home etch.
http://www.freestompboxes.org/viewtopic.php?f=21&t=865
Dont laugh but is there anything available where give it the schematic and it lays it out for you....and then solders it..na Im jokin about the solder part but not the first bit
There are some programs that do auto layout and routing but they're not that smart about not routing signal through buzzland. There are some where you place the components on your virtual PCB then does the routing for you but again, it doesnt know not to route your audio signal through buzz laden territory. ( the pay for version of Eagle does this) Its generally best done by hand. If you use auto route, you need to thoroughly check the way the program routed and make corrections to avoid this but good layouts can be a real pain.
