erol said:Hi,
Were can I buy full 500 DIY EQ kits?
Is there He69 full kit available for example?
ramshackles said:erol said:Hi,
I sell He69 PCB's. No full kit at the moment (front panels available from frontpanels.de).
I'm working on an 'Easy He69' version, which I will do a full kit for if there is enough interest.
Yes thats right. You will need to request the mounting bracket along with the frontpanel from frank (frontpanels.de)erol said:ramshackles said:erol said:Hi,
Cool! Would like to buy the Easy He69
What do I need to build the fulll He69:
1 Frontpanel from http://www.frontpanels.de/frontpanels/igor-s-projects/
1 PCB from http://ramshacklerecording.com/collections/equalisers-1
ramshackles said:Yes thats right. You will need to request the mounting bracket along with the frontpanel from frank (frontpanels.de)erol said:ramshackles said:erol said:Hi,
You can download the docs from our website; you will need to source all the components yourself.
I wouldn't recommend it for new starters...it's fairly tough. The easy69 will be just that...an easier build. I'm checking the PCB design now so will probably start a new thread for it in a couple of days.
nielsk said:Have you looked at the White Market thread?
Most of us offering kits have postings there...
toobnoob said:Pultec 500 series
http://groupdiy.com/index.php?topic=46920.0
sahib's eqone (Amek)
http://groupdiy.com/index.php?topic=52462.0
Sound Skulptor kits
http://groupdiy.com/index.php?topic=33492.0
jsteiger said:I have an ad in the WM but it is hard to show everything there. My EQ kits can be found here at my store http://classicapi.com/catalog/index.php?cPath=22_117_119
Thankstoobnoob said:also DBdawg audio for Calrec eq
http://www.dbdawgaudio.com/
nielsk said:There are many full kits listed in the White Market by members here.
Kits like ours are complete with every component required to build, sans 2520 type op amp (which are available built and as kits in so many forms) as many have a variety that the prefer or already own.
Our posting in the W/M helps to support this forum, and buying from those who post there helps support as well.
