Does anyone have schematics for one of these? I was just given one and it flashes all LEDS when plugged in. This is a indicator of a voltage problem but I believe the problem is in the circuit not the line voltage.
After more inspection, the unit seems to work but the line voltage indicator circuit seems out of cal or faulty to some degree. I get 118vac at the wall and with the unit on I get 118vac from its outlets.
The line voltage lights are all on indicating I am getting around or over 128vac which is not the case.
Any info would be great.
