Hi All!
Thanks in advance for any help and guidance. I finally got around to working on a set of G Pultecs that I've had around for a while and one them is very close to completion. I'm not super circuit savy and just wanted to confirm a few things with the PSU and grounding.
First thing, grounding. Are there any extra connections that I need to make for proper grounding besides the connections on the circuit board and pin 1 on the xlr in and out? Right now I have nothing connected to the third prong of the power plug and that seems suspect.
And for the PSU is there anything special with regard to 220v Vs. 110v? I bought the triad FS12-1000 transformer from the original BOM (http://parts.digikey.com/1/parts/998035-transf-6-3vac-2-0a-split-pack-fs12-1000.html), was that the right move for 110v? Do I have to wire it in a specific way for 110v operation? Does anyone have a pic of the correct wiring for both power transformers? That would be super helpful, I think that I did it right but I'm not sure.
I'm getting the tubes in a few days. Is there anything that I should do before I pop the tube in and fire it up so I can avoid disaster/destroying components? I have a multi-meter but again have never used it...
I attached a pic of the PSU section if that helps any:
Uploaded with ImageShack.us
Sorry for the long demanding post
Andrew
Andrew
