daveee
Member
I'm modifying my G-Pultec to make it stereo... and I'm planning on using dual-gang stepped pots, as I figure it's the best way to get symmetry between the channels.
However I can only get (affordable!) 10k and 100k linear and log stepped attenuators.
Do you think it would be OK to put a resistor in parallel with a 10k pot to make a 1k pot and also the same for the 2.2k pot? I know this is possible as it's just parallel resistors; for example, using Rparallel = 1/(1/R - 1/Rpot) ... I would need a 2.7k resistor in parallel with a 10k pot to make it 2.2k.
Or is it not as simple as this? I understand this can change the taper, which I'm not as worried about if it's not too different.
many thanks in advance
dave
dave
