Hi, this is my first post so please be patient with me.
I have previously built 5 G-Pultecs for a studio I worked in, they worked.
I am no longer a pro engineer, i'm back in the playing and writing.
I am thinking of building my own simple G -Pultec based console.
The idea: 16 Pultecs in a frame with outputs wired to a 'New York Dave Passive summing mixer', including pan and fader for each channel.
So far so good.
Now I figure i need a gain stage that I can control as the output, so of course the G-Pultec SRPP buffer,...
Q1. What is the gain of Gyraf's SRPP buffer?
Q2. What is a simple and effective method to attenuate the SRPP buffer? (ie master fader-there are off course L and R SRPP Buffers).
Q3. How do I change the actual gain of the SRPP buffer?/Can it be increased/decreased and how much without compromising the Sound Quality?
A further bonus question;
Given each "Channel" has a complete G-Pultec acting as Channel; input, EQ and makeup Gain...
Q4. Can Channel attenuation be designed into the actual G-Pultec and therefore removed from the 'New York Dave passive summing
mixer'? Pro/Cons, suggestions? (Hint: If a suitable solution is applied to the SRPP buffers in the makeup gain amp on the output of the summing mixer, can't the same design be incorporated into each Channel (Each Channel being a G-Pultec)?
Thanks.
So far so good.
Thanks.
