OK....I have read the big thread, posted to it and tried various things and I still cannot figure out what to do next.
I have a 1176 I am working on that seems to be doing quite well except when I try to switch the meter. I put on a push button switch so it is not quite like the PDF guide. Anyway, the meter will jump and then stay at that point when I switch. I don't have it calibrated so I am not sure if that will make a difference.
My voltages looks fine around the GR Control Amp transistors and they look ok:
Q12:
E: 15.14
B: 4.59
C: 4.06
Q13:
E: 30.53
B: 15.15
C: 14.57
Q14:
E: 16.95
B: 3.54
C: 3.00
Q15:
E: 16.43
B: 16.93
C: 30.51
The only one that is more off as compared to the schematic is Q15 but I figure this is ok. In the schematic it is: E: 16.72 B: 17.25 C: 30.3. That is not that far off so I figure ok....
SO I decided to take DCV at points 7, 20, 21 with no signal. I came up with these:
POINT 7
4: -0.497
8: -1.863
12: -2.024
20: -2.721
POINT 20
4: -10.11
8: -6.21
12: -5.76
20: -3.75
POINT 21
4: -0.605
8: -2.545
12: -2.772
20: -3.741
I have checked the Ratio Switch board which I am using to connect to my push button and it looks fine. No solder bridges or wrong components.
Note, I wired the switch exactly like this picture (picture was updated to the text below it):
http://www.groupdiy.com/index.php?topic=5075&highlight=#img_4534
Something tells me that my problem is at the switch....
I need some help cause this bad boy is driving me nuts! I want it done already
Michael[/url]
Q12:
E: 15.14
B: 4.59
C: 4.06
Q13:
E: 30.53
B: 15.15
C: 14.57
Q14:
E: 16.95
B: 3.54
C: 3.00
Q15:
E: 16.43
B: 16.93
C: 30.51
POINT 7
4: -0.497
8: -1.863
12: -2.024
20: -2.721
POINT 20
4: -10.11
8: -6.21
12: -5.76
20: -3.75
POINT 21
4: -0.605
8: -2.545
12: -2.772
20: -3.741
Michael[/url]
