seavote
My G7 is up and Running. It sounds great. Thanks Gyraf .So I'll share my Parts list for the project.Here now are sources for the mic components. These components will fit on the pcb for the project although you may have to adjust the pins on some of the components.there are many options out there but this can help get you started. the 470K resistors in the mic and the 100K resistors in the mic should be matched for best results. i only listed the amount required to populate the board you may want to order more so you can find a match
THE MIC
1 L.D. capsule CEK12 and mount http://www.pelusomicrophonelab.com/capsnmnts.html
1 EF86 Pentode Vacuum Tube I had a nos telefunken but I also bought a J&J from Eurotubes for my next G7 http://www.eurotubes.com/
1 Lundahl LL1538 Mic input Transformer w.kandkaudio.com/transformers.html
1 Noval pcb tube socket http://www.tubesandmore.com/ part# P-ST9-222
1 7-pole xlr connector,male, chassis mount http://www.redco.com/shopdisplayproducts.asp?id=104&cat=7+pin+Male+XLR+Connectors
Resistors
2 1G Mouser.com part # 588MOX 200001007JE
1 33M alliedelec.com #6480228
2 470K Mouser.com #660MF1/4DL4703F
1 100K #660-MF1/4CC1003F
2 10K
#660MF1/4CC1002F
1 1.6K #71-CCF07-J-1.6K
1 220ohm #271-220-RC
Capacitors
1 220uf/35V electrolytic I ordered Rubicon ZA from http://www.referenceaudiomods.com/ shipping was more than the 2 caps I ordered. Check gregs parts list for this project in metas
http://members.cox.net/capstanrecording/G7/G7_Parts_List.pdf
1 2.2uf/250V Polyester Mouser.com #5989-250v2.2-f
1 1uf/630V Polyester This cap is way over the required voltage rating
it works fine but is quite large. Again check gregs parts list. I got this at http://www.justradios.com/
2 100nf/200V Polyester Mouser.com #75-225p200V0.1
I ordered the 2 styoflex (polystyrene) caps on E-Bay. Again, you can use the parts sourced by greg but I believe he used polypropylene.
THE PSU
Resistors
2 Vishay/Dale 1/4WATT Metal Film Resistors
1/4watt 100Kohms mouser.com #71-RN60D1003F/R
1 Vishay/Dale 1/4WATT Metal Film Resistors
1/4watt 10Kohms mouser.com #71-RN60D-F-10K
1/4WATT 1.8KOHMS 2% mouser.com #71-RL07S-G-1.8K
1/4WATT 470OHMS 2% mouser.com #71-RL07S-G-470
Capacitors
2 CDE Snap-In Electrolytic Capacitors
250V 470UF (25X40) mouser.com #5985-85-250V470
2 Vishay/Sprague Aluminum Electrolytic Capacitors - High Temp
1000uF 35volts 20% mouser.com #75517D35V1000
1 Xicon Ultra Miniature Radial Electrolytic Capacitors
5X5mm 35V 10 mouser.com #140-L35V10-RC
Other
1 Fairchild Linear Regulators
TO-220 1.5A ADJ VREG mouser.com #512-LM317T
2 MCC Rectifiers - Bridge
400V 1.5A mouser.com #833-RB154-BP
THE MIC
Resistors
2 10K
#660MF1/4CC1002F
Capacitors
THE PSU
Resistors
Capacitors
Other
