johnnytoobad
Active member
Hi, i am working on a mutant vari-mu, i am planning to use a modified federal input/comp/sidechain(but balanced that means2 X 6SQU7) and sta-level output(12AT7/6V6), these "stages" will be coupled by 0,1u cap adn 500K, that makes a 3hz high pass, which is fairly good enough for bass... but i wasn't sure of using a pot there before the 12AT7 to use it as an output gain control, and the value of it, the sta level using 330K.
I was thinking about it, because this could be great to use with the output pad to get some crunch with heavy outpad and pot to max (lower R on signal path), or cleaner driving less the out stage padding less...
is it worth (the time, money, hole on the front panel...) adding this pot? wich value would you use???
