New patient on the bench...
Good news...It works. Signal passes, sounds good. No distortion, no smoke.
Bad news....It's "weak." I haven't put a load on it and measured, but I'm guessing it's maybe a third of it's rated 300W output, if that.
Checked the voltage rails...Should have:
+/- 85V
+/-60V
+/-15V
Actually have:
+75.7/ -75.8V
+59.7/ -59.7V
+14.3/ -15.5V
So obviously, the power rails for the 300W amp are off.
Power transformer has dual secondaries, one for the +/-85 and another for the rest of the voltages. Secondary AC voltage for the 85V rails reads 113VAC, and post rectifier, +151.8 VDC. Disconnecting the 85V rails from the power amp doesn't change things.
The schematic has a few voltages to check...They all look fine (within a tenth of a volt). The bias was off a tad according to the schematic...So I tweaked that up but no difference. I would think with this topology that one bad output device would take them all out, so it wouldn't pass anything...Am I missing something?
+/- 85V
+/-60V
+/-15V
Actually have:
+75.7/ -75.8V
+59.7/ -59.7V
+14.3/ -15.5V
