gar381
FOR SALE garSPA-62 proto Discrete Op-Amps from my little Sphere Desk.
These guys sound Fabulous!! If you ever wanted to play with the sound of
The Eclipse this is your chance. Note that these are +/-24volt op-amps
These do require a 12pin (6x2) .156 pitch Card Edge connector. These are NOT 2520 ( 6 X 1 single row EDAC connectors will work with these )
Pinouts. All Transistors are major brand NOS.
CARD EDGE CONNECTORS NOW INCLUDED
The SPA-62s were used in the Eclipse for summing and Line amps in the Eclipse A & B
In inverting mode. Summing bus Rs were 20k.
The line amps were designed to drive a 600:600 load thru a series 470/16 cap
but the will drive a 75 ohm primary trafo with no problem.
SEE.. Sphere
In the Eclipse C they were also used for mic pres replacing the M1200 Mic-pre cards
That were used in the A & Bs.
Enclosed here is an exact reverse of the original SPA-62. Also is a layout
Of these Rev4 proto pcbs. This layout is about 99% the same as the original.
These protos are different from the original as follows otherwise they exactly
Follow the original skitz.
All Rs are 1% metal film (originals were 5% carbon film)
The cogs are now 5% Murata caps (originals were 10% ceramic)
The rail caps are now Panasonic FCs and up sized. (originals were tants)
Input coupling tants are upsized Value and voltage.
Note that the Rail tants were a problem with the original SPA-62
as they liked to short but at least the 313 bulb would light
Saving the the PSU from going down. The later SPA-62s were
Changed to upsized ALUM electros to fix this problem.
The reason why these are for sale as I am changing out all my SPA-62s for
My new Production pcb that is a cross between the SPA-62 and the SPA-62A.
Pricing…
4 packs for$200 shipping included to the lower 48 states.
8 packs for$375 shipping included to the lower 48 states.
New pricing below
USA only please as I have had trouble with international shipping
In the past.
Thanks for looking
Gary
SEE.. Sphere
Pricing…
4 packs for
8 packs for
New pricing below
In the past.
Thanks for looking
Gary
