I am trying to detach the circuit board so I could resolder those Molex connectors ,but eventhought I have remove the screws and loozen the four nylon spacers the board does not seem to detach. :-\
Well, going by the steps described there, the "amplifier deck" would seem to be the entire rear panel assembly. There must be some sort of hinge(?) on the right side, if the whole thing should be able to be swung open (as per 4.3.1).
It's actually indicated not to reuse them, anyway.
Hmm... Any chance you can slip a flathead screwdriver in there somewhere? To try to lever up the transistors...
Or actually, wouldn't it be possibly easier to desolder the transistor legs, maybe bend them out of the way, and then remove them separately, after removing the PCB?
Some photos of the insides might be useful (since the diagrams in the service manual don't really show exactly how those transistors are mounted)
If your talking about the molex where the XLR plugs in with a ribbon cable, It usually is in the hold down plastic part that slides in. I had this problem with mine which are from 1994 vintage and would up soldering around the connector. Those connector need replaced after years on mine. The connect it self stayed soldered to the PCB but the clamps or plastic hold down had gotten sloppy and created an intermittent connection. I also had problems with the mute transistor T101 that had to be replaced. other than that they have held up very well.
