Roland Orzabal? He uses a Roland Jazz Chorus, how weird is that>
Intuitive experimentation can sometimes be the quickest way to get a good ground scheme.
Doesn't have anything to do with plugging an unbalanced output into a balanced input, which *is* ok
I don't get it. I don't see a balanced output.The right pin of the Interf connector is a control pin that changes the internal gain of the circuit, allowing the same (unity) gain for both balanced and unbalanced connection.
Balanced out is in page 3.I don't get it. I don't see a balanced output.
It's a "copy" of the Roland Dimension D. That have 30 years. Haible said, he wouldn't design it that way either. He only respects the original design.Of course it's OK, but the connection shown in the JHaible design is not optimal from a noise/interference rejection standpoint. The design also appears to have pin 3 as hot, which is about 30 or 40 years out of date, so maybe not completely surprising that it is not following best practices for shield connection which have been widely taught for more than 25 years.
The two op-amp instrumentation amp configuration used for the input stage is also a little different than the canonical version, which makes me a bit suspicious that the designer doesn't quite fully understand differential inputs, so I would suggest keep the good parts of the signal processing that you want, but improve the I/O connections to modern standards.
OK. then I don't see the connection (pun intended) with grounding...Balanced out is in page 3.
http://jhaible.com/legacy/subtle_chorus/subtle_chorus_main_board_sch_dwg3a.pdf
I don't catch youOK. then I don't see the connection (pun intended) with grounding...
The connection ( pun inded ) is that I don't know how to wire this thing properly.OK. then I don't see the connection (pun intended) with grounding...
I don't know how to wire this thing properly...shield cables, circuit gnd, chassis and safety earth.
Roland perhaps expected the use of cables where pin 1 is not connected to the shell.
Dimension D, and pin 1 of the XLRs are all connected to signal ground
I think that I will wire like the original.
I was grounded a few times as a child. Once was for being expelled from school for a week after lighting my volcano science project inside the "high" school. An entire wing of the school filled with smoke which resulted in a school wide fire drill. I mean common man, it was done in the name of science! And the fire drill was a success. I took that as a win-win, but the assistant principal didn't see things my way. I was grounded for that week off of school and my old man made me chop a cord of wood with an axe. Memories of grounding!go wireless,
two prong cord safer than three prong in some instances,
(chassis is floating so git player is floating) (not on LSD, i mean electrical)
although i played some of my best stuff on acid, but the fret board started to melt, so i had to switch to shrooms which apparently they are now using to treat depression,
we had a 30 page argument about grounding a while back which alienated a few people , for some reason, grounding is an emotional topic,
