got some r-core trannys from the bay, unusual wiring, how to check ?
Axelerator
Ruhrpott (north-west-germoney)
hi, i recently got some r-core trunnys , and they have an unusual color schem i think.
the printing says two secondarys @ 24 volts,
first :
blue, blue
second :
white white.
as i want to parralel the secondarys i think i would have to know which are in phase..
my oszilloskop is broken, so is there another way of checking the phase without destroying the transformer ?
thank you for helping me out  !
axel
Hello,
Maybe something here may be of some use to you...
Reply#1 by "Psi" in the following thread describes one method of getting the phase right when paralleling two identical secondaries of a transformer (or the secondaries of two identical transformers).
www.eevblog.com/forum/chat/putting-transformer-windings-in-parallel/
For additional safety while doing this testing you can use a variac to feed a lower voltage into the transformer's primary, or temporarily feed the primary from a low voltage secondary of a spare, low current transformer, or safest yet; feed the primary of the transformer under test from the output of your signal generator (set to 50/60Hz). That way you can test the various connections of the two secondaries without the drama that might occur if the transformer was simply connected to the mains while doing your phase testing.
Regards,
Frank
What I think you should do:
Get a switched power strip with a lamp so you KNOW when the power is OFF.
Get a 6 Volt AC supply: wall-wart, filament transformer with proper line-plug wiring, etc.
If you apply less than 1/10th rated voltage to a transformer, it won't burn-up for many minutes or hours.
Get clip-leads for your voltmeter. Don't have your fingers anywhere near any leads.
Meter one of the secondaries.
Apply the 6VAC to the (120V or) 230V primary.
You expect a "230V:24V" transformer, fed with 6V, to make about 0.6V on the "24V" secondary.
BUT if the label is wrong, and you put 6VA into a 24V winding, the winding you are measuring will be about 60V, which is somewhat dangerous. (Why you keep your fingers AWAY.)
If all is right and one "24V" winding gives 0.6V, power OFF, clip the other 24 winding, and check it.
Now clip one end of one winding to one end of the other winding, meter the end leads.
If you get 0.0V, you are correctly phased for parallel connection. Connect the end leads together, done.
If you get 1.2V, you are phased for "48V" *series* operation. That is not what you asked for; however someone else may want series.
A 'scope is a very poor tool for checking phase on two separate windings. A single-channel 'scope is always "in-phase" (the display locks to the wave). A dual-channel 'scope works IF both channels can be swept with the same sweep. However mistakes happen. The voltmeter is clear: if two leads have 0.0V between them, they are in phase; if double-voltage, they are out-phase.
Actually with the 6 Volt "dummy wall voltage", once you are SURE you didn't get pri/sec wrong, you can sorta just try all combinations with your fingers live. If wired out-phase, when you brush the wires together, they spark. In-phase, no spark, you get the expected voltage, and the transformer shows NO heat after 1, 10 or 60 minutes.
